paddingtonfire
- Feb 16, 2013
- Location
- London / East Anglia
- 1992 W124 300TD Estate & 1982 W123 280TE
Good morning,
I've recently purchased one of the above vehicles, a '92 model. 225k on the clock, OM603.912 engine. The guy who sold it to me said it had been running on veg oil, but changed the filters before I got it, and they do look new. Starts fine, a little bit of a rough idle, but when I put my foot on the accelerator she sounds sweet.
Around town, lovely, it glides, not the fastest by any means, but appears fine. However, when on the motorway at between 50 and 70 mph on a very slightly uphill gradient I get what can only be described as juddering and a loss of power that if I floor the pedal it gets through it, I can maintain speed but the guts go and it's happening regularly. Then, after travelling for some time at motorway speeds the engine tries to die when I slow to a stop. If I keep the revs up it gets through it and returns to normal when trundling around at slower speeds.
Before I put it into a local specialist, I wondered if there was anything I could do first. Could it be the veg oil has played a part, do I need to flush the fuel system or purge it? Is my injector pump playing up? ECU? Relay? Should I change the filters again.... I spoke to one guy who said use the more expensive diesel? Help!
Thanks in advance,
Mike
Thanks in advance,
Mike
