BlueQuinn
What likely causes are there for my car to overheat? I'll tell the whole tale in case anything is a clue.
I came off the motorway where the customary 80 degrees showed on the temp gauge and into a traffic jam, where it got hotter. This I expected, but then the needle kept rising into the red and sure enough lots of steam and fairly new Comma red coolant escaped.
After waiting for it to cool I poured 3 litres of expensive spring water into the header tank and went on my way, taking a circuituous route to keep moving and keep air coming through the grille. I made it the next 20 miles thank goodness. Needle staying at 80 when moving, but creeping up when stuck in traffic. It stayed below 100 after that
So what's going to be wrong?
Fan broken? Thermostat gone? Waterways furred up?
It's done 208000 miles and between 124000 and 136000 it had both radiators, thermostat housing, coolant level sensor and water pump replaced
Last coolant change in January.
Last MoT a week ago I was shown a small coolant leak from somewhere. Barely noticeable.
