punjabi
Where could I find a detailed procedure for an 300TE autobox oil change? I have purchased the original MERC filter and sump gasket and am not sure whether the normal ATF or Dextron III is the correct oil - is the Halfords or ECP ATF good enough or does it have to be the MERC oil!?! Although the oil on the dipstick is clear and clean, I notice that there is an erratic changeover sometimes since my 600 mile day trip up North and back last week.
Also, what's the correct way to check the oil level - engine running and in Neutral? Where should the level be on the dipstick as it has 2 wavy sectors?
