Aug 18, 2023 #1 G GrahamBartley New Member Joined Jan 26, 2023 Messages 8 Location milton keynes Car w124 ce320 cab W124 320 5 SPEED AUTO GEAR BOX CHANGES GEAR TO EARLY 4th gear by 20mph any ideas .Thank you.
Aug 19, 2023 #2 R ray_hennig MB Enthusiast Joined Dec 1, 2008 Messages 1,347 Location France Car MB 300CE-24 Sportline Check that the Bowden cable and vaccum line to the gearbox are installed OK. Then clean and ensure correct function of E/S and 4/5th switches. Then think about the gearbox controller and or wiring to/from it. All this is relevant to my slightly earlier car. Yours may be different. Others will know better than I. RayH
Aug 19, 2023 #3 OP OP G GrahamBartley New Member Joined Jan 26, 2023 Messages 8 Location milton keynes Car w124 ce320 cab ray_hennig said: Check that the Bowden cable and vaccum line to the gearbox are installed OK. Then clean and ensure correct function of E/S and 4/5th switches. Then think about the gearbox controller and or wiring to/from it. All this is relevant to my slightly earlier car. Yours may be different. Others will know better than I. RayH Click to expand... Hello there. I have replaced E/S and 4/5th switches. They don't seem to work power there switches OK ?. and I have replaced gearbox controller. trying to see vac pipes very hard to see .and checking wires . Thank you. Click to expand...
Aug 19, 2023 #4 grober MB Master Joined Jun 22, 2003 Messages 31,720 Location Perth, Scotland Car W204 ESTATE http://www.w124performance.com/docs/mb/other/tranny_722_Mitchell.pdf
