novisen07
Hi, start by apologizing for my English. Hope you understand.
I have a w124 1988 gasoline with pieburger carburetor which a while ago started to fuss. i have changed spark plugs, cables, distributor cap, rotor, ovp relay temp sensor but nothing helps. It sometimes starts cold and goes perfectly. When it is warm it can run without any problems. When it goes it goes smoothly and without any problems. When it does not want to start at once, I have to wear it for a while. Starts but has a very weak and flabby run for one minute, then it gets speed and can go well for a long time. It is my problem that I do not know where to continue in the search. Haven't found any vacuum leaks. Have used starting gas in the search to find any leaks.
Hope someone can give my tip.
Please
Soon it goes to the scrap metal
Please
