LINDS HANSON
- Jan 30, 2005
- Location
- cornwall uk
- 190 Evo 1, 190 sportline plus,300te sportline
Hi we recentley bought a 95mwy E220 estate the ABS light was on and we stupidly thought it would be a simple OVP fault or at worse a speed sensor issue. The light is on at all times even with the car staitionary, it flicks off for a second when the ignition is turned on then immediatley returns and stays on. We have swapped the OVP relay with our other car, swapped the ecu, swapped the pump unit , swapped pump and main relays, replaced rear speed sensor because resistance was at the low end of tolerence all made no difference. I have checked voltages and earth resistances at the ecu multiplug all appear to spec, if the main relay is removed the light goes out. the wiring between pump and ECU tests good for continuity. Am I right in thinking that the speed sensor's [which all test out OK anyway] do not have any effect on the warning light until the car is moving? and what needs to be done to clear a fault from the memory once repaired? What does the wire from ABS to engine ECU do? This really is bugging me now any ideas would be most welcome
