Is a/c really that necassary in UK?
Definitely with
The system is fairly easy to overhaul/repair.
The most common failure is the condenser which rusts through due to all the leaf mulch and other crap which gathers in the radiator
Tend to agree with "TJ"----in theory A/C is desirable---- but for a car of that age factor in ---possible reliability problems, probably uses a banned refrigerant!, can smell badly if its been neglected, or the drains are choked, leaky systems need frequent regassing etc etc and it becomes less attractive. So only buy a car with the original factory fitted equipment which has documented evidence of money spent in maintaining it. As Pontoneer says its mainly fitted to top spec cars which fetch "all the money" in good nick. In a neglected car air con is often the first thing to "fall by the wayside" since its a complicated but non essential system.Without. Unless the AC system has been kept in top fettle. Less to go wrong. Sunroof and windows work fine for me, plus plenty of "puff" thru the centre vent when the fan is on IV.
Can be an expensive thing to do , relative to the cost of the car , most W124's now change hands for hundreds rather than thousands of pounds .
If you get a car with an R12 system that hasn't been touched in years , the cost of conversion can be quite high .
