aka$h
When I bought my 124 the air con wasnt working, as usual the seller said, it needs a re-gas.
Went to VCC (vehicle climate control) through Georges reccomendation, and it turned out to be a hole in the condenser, and one of the fans was also faulty, £330 later, its blowing ice cold air!
Apparently the fans fail which causes exceptionally high pressure within the system which is often the cause for leaks, so just check your fans come on when you run your a\c.
