W124 auto Gearbox oil
reeventu
Hampshire
E320 Cabriolet
As my first post I would like to ask a probably frequently asked question.
I know that the gearbox oil should be changed around 36K, but can you confirm the oil specification to use.
Also is there a filter that should be changed or cleaned at the same time
Thanks for the help
Dextron II is fine - but i used the genuine merc stuff but at almost £80 for the correct amount i think i may just use standard Dextron II next time.
Yes there is a filter inside the pan. 3 self tappers hold it in. replace it with a genuine one IMHO.
make sure you replace the sump pan gasket for a new one afterwards
dont torque up the pan bolts too much otherwise you will distort the pan - nip them tight (just over finger tight) or buy a torque wrench.
dont forget to drain the torque converter
be careful not to over-fill. it takes 7 litres but you may not get all out so use the dipstick and maybe the old drained oil as a guide.
this is all for a 722 box.
yours is very similar to this how-to, but the 124 wont have the too-tight safe pan bolts so beware;
http://www.mbclub.co.uk/forums/showthread.php?t=23969
Excellent quick response
Thank you
