W124 cabriolet interior lights and things
  • Thread starter Deleted member 11979
  • Start date
So, replaced door switches and no change.
The relay clicking is the light control relay 126 542 03 32
When the ignition is on and the doors open and close the relay is silent and the interior lights respond correctly
Ignition off relay clicks and lights don’t respond, remaining on constantly , does that tell anyone anything?
Thank you for your continued help
To hopefully close this thread and be of use to others who have similar problems.
The lights now behave, I had an hour so did the following:
Changed all the fuses
Changed the light control relay for a good one from my w126 (w124 one works in w126 so doubt that was the solution)
Discovered the map light switch was a bit dicky so worked it a few times until it consistently worked
Either one or a combination of the above has solved the issue, but I was wearing my w124 t shirt so that may have been it too, thanks for those who inputted
124 tee shirt....?
