the IR central locking used to work but not for a few years, but this is whats happening now, the IR key fob won't open the drivers door or tailgate also turning the key in the tailgate or drivers door lock will only open those locks,
but if I open the drivers door from the inside all the locks will open but the pump runs for 15 or 20 secs and just as the pump stops theres a click from the tailgate lock which could be the suspect, if I push the button down on the drivers door they all lock and the pump runs for about 4 or 5 secs as I it should do.
I took it into a inde merc garage and I think they are a bit stumped, they said I need both the IR sensors and a IR control unit first, and then see if that works,the IR sensors are a bit milky but not that bad.
ive nearly got the car back to where it should be and this is one of the last things that needs doing so any help or insight would be much appreciated, sorry should of said its a 1995 E220 estate.
