Hello all,
Please help me to solve cold start problem on W124.
Mercedes W124 230E 1992 year(K) engine code 102.982
Cold start.First start after 8 hours on the drive way.Outside temperature is 20 C (summer time) Cranking too long when engine start after 3 seconds everything is fine and you can drive or rev the engine no problem.
Cold sart in outside teperature 5 C (winter time) Cranking shorter before start but still no good.
OVP is new both blade 10A fuses on the top of OVP are new.
There is ABS light before engine start then disappeared as should be.
In outside temperature (summer time) I did disconect cold start valve before cold start and there is no differents.
Thank You
Thank You
