a friend has e220 convertible roof folds fine inside compartment, the problem once it closes when u want to open u can here it clicking and not openning, if u get the spanner and open the cover manually and then use the button to close the roof it works, it is this step to get the cover to open is the problem.
it is obvious the roof releases from the back cover opens, the front roof folds ok into the pit, and closes, but as soon as u try to open when loaded it does not work electrically but does work manually.
also i noticed when it is folding the black cover clips the clip on the metal cover which i never seen happen on other w124 convertibles.
also is their a way of releasing the clip off the back of the car if it is not closed shut this for another friends car, if somebody has any trouble shooting manual for w124 convertible it would gr8
