CreosoteChris
Hello MBClub-bers – hoping someone can provide some guidance to get me out of the total screw-up situation currently afflicting my W124
Vehicle registration: K834 CNC
VIN: WDB1240422B901344
Model: Mercedes 220CE, auto, sunroof, no air-con
First registered: January 1993
Some time ago, I started having occasional issues with front wheel rubbing on my ’93 220CE (contacting wheelarch when going round bumpy turns) and also an MOT advisory that noted front tires worn on the insides. It was pretty, from the appearance of the vehicle, that the issue was “tired” and sagging front suspension causing the wheels to slope inwards – sort of /-----\ , and reduced ride height. I decided to get the springs replaced, also new shocks to go along with them.
I contacted a UK parts supplier and went through a fairly lengthy discussion trying to identify the right items, even going to the length of getting my mechanic to inspect the old springs in an attempt to identify them, checking for remains of original paint. He commented
“As expected for a 25-year-old car, the springs are corroded, but I cleaned them up with a wire brush and saw
- Top part of spring - evidence of YELLOW paint
- Bottom part of spring - evidence of BLUE paint”
Eventually the UK supplier advised that they couldn’t figure out the correct part numbers, and said they couldn’t help. I thought that German suppliers might have better insight and went to euspares. The seemingly helpful sales staff there advised me to get the following Sachs items.
Shocks Buy SACHS SHOCK ABSORBER Item No.: 115 069, EAN 4013872020546 online Springs Buy SACHS COIL SPRING Item No.: 997 109, EAN 4013872344352 online
After fitting, see appearance in attached photo: I sure don’t have a wheel-rubbing problem any more, because the ride height is now 50-60mm above standard
I pointed this out to euspares support, whose replies can be summarised as
So it’s been a rather long and sorry tale (this is actually the abridged version) and it seems to boil down to this: My VIN (unlike others, it seems) doesn’t accurately identify the front springs, so no-one knows what to supply to replace them. All I know is that the current Sachs units are listed as Length [mm]: 427 – and are far too long:
Any ideas on where to go from here?
Thanks very much
Chris
93 220CE, auto, red / black leather, 138k, Manchester
- That’s the shortest variant of Sachs front spring compatible with your car
- We couldn’t get the OEM part number from your VIN, so we picked the most suitable “compatible” product.
Thanks very much
Chris
