w124 coupe no radio signal
horgantrevor
w202 c43 & w210 E220 CDI estate w219 W221
hi i have a friend that has no radio signal the usual items have been checked
the model radio is mexico typ 2330 becker cd radio fitted from factory
is their a amp in this car for the radio in the rear pillar
any help would be great
we have noise from speakers just no radio signal
Have you checked the conections at the antenne and the back of the radio? Dose the radio antenne extend fully?
it wont extend fully but all connectors are good checked all but i never checked if their was a radio amp in the rear pillar like the w202 for the RF and IR signal
Not usually a radio amp in the normal setup- just a straight coaxial cable. Possibly a bad /corroded antenna ground strap to earth connection where it attaches to the car body or broken antenna strap
On my estate there is no signal atall untill the antenne is fully up.
How far dose it go? A w124 has quite a tall mast.
it only goes up about a foot
its a friends car he only called for a small while the other nite so i didnt have much time too look at it as he had to go
ill keep you posted
thx again for the help
No amplifier but our estate had a second junction connection in the drivers footwell. When we got the car the radio signal was rubbish. On investigating there were 3 different aerial leads presumably from various new aerials fitted in the life of the car. Turned out the current aerial was not connected to the lead going to the radio.
yes ill see the car again soon ill have more info then
thank you for the ideas to check ill post back
