W124 Coupe - Rear Headrests will not go down
Bill_33
Hampshire
A160,(W169) previously 300TE - 300CE, E280TE
1993 W124 Coupe - pre face lift
Just checking through my new purchase
The rear head rests do not fold down when I press the button on the dash
Is this normally a simple problem
Any advice gratefully received
Cheers
Cheers
Yes it I think it will be. There is a red fuse (also for the radio, glove box and cigar lighter) . Check the fuse box, drivers side, I cannot remember which on it is, but unlcip the lid, and there is a piece of paper underneath (also its in your handbook) it tells yuou which fuse. If none of the other items work, then it is this fuse. If not, try removing the wood and getting the switch out and squirting WD40 in it and wiggle it for a minute or 2.
Like backrest, vacuum operated. Try again with engine running.
Thanks - I have tried with engine running
Cheers
