W124 E200 ideal oil
W124ali
London
W210 E200 Kompressor
Hello all
Changing the oil and filter on my 1995 E200. Any recommendations on what oil is best?
Which Engine Oil? These 3 links should help. Each will open a new Tab/Window so you can switch between them if need be.
Determine engine type (First three digits of engine number which can be found on V5). to establish which approved spec number to use. Also refer to the 'Notes' at the bottom.
___________________________________________________________________________________________________________________
Engine Type / Prescribed Specifications for Service Fill Engine Oils (MB Sheet 223.2)
http://bevo.mercedes-benz.com/d/d/en/Spec_223_2.pdf
____________________________________________________________________________________________________________________
MB Approved Multigrade Engine Oils (Other Spec sheets can be selected by clicking on 'Select Sheet' (Top left)).
http://bevo.mercedes-benz.com/bevolisten/229.5_en.html
Mercedes Oil Specifications
http://www.oilspecifications.org/mercedes_mb.php
