Screwdriver
- Oct 20, 2008
My 1996 E220 has been facing a curious 5-6 minutes delay in cooling each time the A/C is first engaged. Here are more specifics from my troubleshooting:
1) The delay in cooling happens the first time the A/C is turned on. Once the compressor kicks in after 5-6 minutes, cooling promptly occurs each time the A/C is subsequently turned on. It's only the first time that this symptom occurs i.e. A/C pulley does not spin till the 6 minute period passes.
2) The delay does not depend on whether the engine is cold/ warm. The delay occurs regardless, the first time ac is turned on. Once functioning, it exhibits no further delays.
3) Thermostat temperature lowering does nothing.
4) Changed A/C relay near the battery as we suspected a failure. No result.
5) Once cooling does occur, it cools well. Thermostat works correctly and everything is peachy.
It's getting the thing to kick in immediately that's the problem. Any information/ guidance that I can share with my greasemonkey would be appreciated!
Cheers!
Cheers!
