D
Deleted member 11979
Guest
Just a quite note that maybe of use to people in the future, my drivers side electric window went down, then would not come back up again , particularly disappointing!
After arming myself with advice from previous posts here I st about diagnosing the problem.
First port of call the fuse box, sadly all in order there.
Next I checked the switch, as suspected it was ok (the roof switch wouldn't raise the window either, so I thought the switch was ok.
Things would have to get more in depth, so I inspected the wires between body and door for chaffing, all sound there.
Next off came the door panel, swapped the wires on the motor, pressed down, and the window went up!
Hmmmmmmm
Put the terminals back the way they should be, pressed down, and dow nwent the window, pressed up, and down stayed the window.
Put a meter on the motor terminals and pressed up, both were live!
Hmmmmmmm
Well and truly stumped I could hear a small click from the back of the car when I pressed the up button.
Took the seat out, saw a black box with wires everywhere. Merceds was printed on the top, it looked expensive. Very expensive.
Decided to hit it.
Pressed the switch.
Window went up!
Home for tea and medals.
Another day wasted.
Moral of this story, check the black box before disassembling the rest of the car.
Hope it's of use to someone.
Hmmmmmmm
Hmmmmmmm
Decided to hit it.
Pressed the switch.
Window went up!
Another day wasted.
