grober
MB Master
In a recent PM from a forum member he requested some part numbers for consumables for servicing a 1995 W124 E 220 COUPE. This is a list from miscellaneous sources which might prove useful to other forum members. This is not a definitive list by any means and folks should check out the numbers for themselves before ordering but might be of assistance.
For Motor oil I would recommend a good 10w40 synthetic or semi-synthetic oil that meets MB 229.1 or better- 229.3 ----- up to 5.8 litres inc filter
Fuchs XTR 10W40
or
Shell Helix plus 10w40
or
Motul 6100 Synergie+1 10w40
Oil Filter
Hengst E142H D21
or
MB A104 180 01 09
change oil and filter at 6,000 miles
Automatic Transmission fluid
4 speed hydraulic box type 722.428 5.5 litres capacity
FUCHS Titan 4000 up to 6 litres to meet DEXRON 3 to meet MB spec 236.1, 236.5
Or
MB ATF 3353 1litre A 0019894503/10 MB spec 236.12
gearbox sump cover gasket MB 2012710380
Transmission fluid filter MB 1262770295
Change every 36,000 miles
Fuel Filter
Hengst A0024772701
or
Knecht KL65
or
MB 0024772701
change every 36,000 miles
Air Filter
MANN /MB A1110940004
change every 20,000 miles
Spark Plugs
NGK BCP 6ES
MB A0031596703 BOSCH
Change every 12,000miles
Poly V belt FANBELT
CONTITECH
6PK2040 without air con
6PK2140 with air con
Brake fluid
use MB fluid
change every 2 years
Antifreeze/ Coolant mixture
use MB coolant 50/50 mix with water 5 litres A000989082511
change every 3 year
Powersteering fluid
MB A0009898803 500ml-1itre required
P/S Filter Knecht HX44
Change every 72,000 miles
Powersteering damper
MB A1244630432
Change when required 30-40,000 miles
Charcaol filter (petrol tank evap control)
MB A1244700359
Change every 72,000 miles or 5 years
Thermostat (includes housing)
MB A1112000915
Change if necessary
Fuchs XTR 10W40
or
or
Oil Filter
Hengst E142H D21
or
MB A104 180 01 09
Or
Fuel Filter
Hengst A0024772701
or
Knecht KL65
or
MB 0024772701
Air Filter
Spark Plugs
NGK BCP 6ES
Poly V belt FANBELT
CONTITECH
Brake fluid
use MB fluid
change every 3 year
Powersteering fluid
MB A1244630432
MB A1244700359
MB A1112000915
Change if necessary
