W124 E220 down on power, mpg
Discussion in 'Engine' started by Dickie14, Jan 3, 2019.
  1. Dickie14
    Dickie14 New Member
    19
    Apr 6, 2014
    Car:
    W124 E220 Coupe
    Recently acquired a '96 E220 coupe but it is noticeably down on power compared to the one I owned until recently (same age, similar mileage). I'm also getting worse fuel economy - 28mpg if I'm lucky on a motorway run when my previous one would consistently return 30-32mpg.
    Anything I should I be looking at?
    Sent from my SM-G930F using Tapatalk
  2. grober
    grober MB Master
    27,647
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    The obvious one would be a fault on the HT circuitry causing a cylinder misfire, altho that should probably be detectable as a certain engine roughness. The inlet camshaft is variable so a cam adjuster failure to alter cam timing would noticeably alter engine power/ response. Other possibility might be transmission loss or the quite simple throttle plate/ throttle cable adjustment not permitting full throttle opening. Fuel rail pressure should be checked and weak running /combustion problems might be revealed by examining the spark plugs
    Dickie14 and WDB124066 like this.
  3. OP
    OP
    Dickie14
    Dickie14 New Member
    19
    Apr 6, 2014
    Car:
    W124 E220 Coupe
    Cheers for the swift, detailed response! In terms of s misfire how rough are we talking? The engine does sound coarser than my old one but it's not lumpy.
    Going to get the garage to look at the throttle adjustment and cam adjuster in a couple of weeks
  4. grober
    grober MB Master
    27,647
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    With the E220 HT breakdown is normally down to faults with one of the 2 coils located under the inlet manifold- its a lost spark system - each coil fires two plugs simultaneously 1+4 or 2+3 but one cylinder is on the compression stroke and one on the exhaust. If not the coils then possibly the low tension wiring or dodgy HT wiring/plug connectors. Easiest diagnostic is to check all the plugs for any sooting up indicating its not always firing correctly.
    This video on a M104 engine [ same family] demonstrates a rough test for the camshaft adjuster solenoid operation- you will note he limits the current supply!- altho much better to test its operation by checking with a fault code reader. It should also be noted that cars of this vintage are plagued with dodgy engine wiring looms- the insulation cracks leading to shorts/ mysterious symptoms- any signs of cracked or flaked insulation means a new/ rebuilt wiring loom!
  5. coupe addict
    coupe addict Active Member
    111
    Jun 7, 2010
    penzance cornwall
    Car:
    e320 coupe 1994
    Odd faults can arise from partial failure of the wiring to the MAF sensor at the point where it clips to the back of the head. Generally the engine bay wiring loom isn't as fallible as on the M104 engine, but this particular location is is weakest spot. Splitting the outer case of the wiring will quickly confirm or deny the fault: if the insulation is cracked or crumbling a local repair is very easy.
    Steve
    grober likes this.
  6. Vlad
    Vlad MB Enthusiast
    2,401
    May 30, 2003
    Reading, England
    Car:
    Various Mercs come and go
    I would also suspect a failing Air Flow Sensor
  7. OP
    OP
    Dickie14
    Dickie14 New Member
    19
    Apr 6, 2014
    Car:
    W124 E220 Coupe
    Finally got the garage to have a look into this. They immediately noted the throttle cable was a bit slack and tightened it up correctly and wow, what a difference! Feels like a different car! It now drives as perkily as my old one so I'm very happy. Doesn't explain the mpg but I'll keep an eye on that.
  8. jpwilliams
    jpwilliams Active Member
    973
    Dec 23, 2006
    Wirral /Axarqia,Spain
    Car:
    W210 DIESEL AUTO EST,LEXUS GS 450h
    Colder weather might explain the increased fuel consumption ?
Share This Page
