grantmackay80
- May 20, 2010
Hi there, I have a problem with my 1994 E320 coupe. A month ago I the problems started when my air con stopped working as did the cruise control, kick down and general acceleration seemed to bog down, the car also struggled at idle and danced up and down. The car ariel started to work when it wanted to as did the window wiper.
I took the car to the garage and the sparkie identified the throttle body as the issue and sent it away to be tested but this took 3 weeks for the company to admit they couldnt test it. The sparkie then sourced a replacement from a doner car and fitted it which fixed most of the problems apart from the window wiper and arial which I think could be the window wiper switch and not sure about the arial issue, the error codes cleared also. There was a new problem where the car would idle at 750rpm at cold and rise to 1100 to 1400 when warm, almost the reverse of what it should. After a day the car started to develop issues where in kick down it would bog down and when you tried to accelerate it would bog down, the car also on occasion would not accept throttle
but that cleared when you turned it off and on again, it also wouldnt change up into fourth gear when trying to accelerate but then did change when you back off a little .
Can anyone please advise me on what action to take next.
Thanks for time Grant
