The purpose is to make a reliable car for cross country touring that has enough carrying capacity to haul those "little things" that one always finds a thousand miles from home.
The means to that end is to covert my Malachite Green/Mushroom 124 E320T to resemble my Malachite Green/Mushroom 124 500E using all Mercedes (or OEM) parts. Just like Mercedes would have done should they have asked me...
I decided against doing the M119 engine conversion because it is beyond my capabilities. I'll live with the lower power of the E320 in the interest of reliability rather than empty the bank account trying to achieve something else. Getting rid of the kats will help a little in the power and weight department. So would missing a few dinners for that matter.
Besides, I subscribe to the belief that a stupid man who knows he is stupid is far better off than a smart man who thinks he is smarter. "Mans got to know his limitations" - Eastwood, Clint - 1973.
So.....
BODYWORK.
FRONT:
No brainer, bolt on. Straight swap of wings, inner wings, bumper and a few other small parts. A little rewiring will get the high beams and fogs sorted out. All new seals, rubber and gaskets of course.
Printed out the EPC on both cars and compared what I need and don't need.
I am trying to decide if backdating the car from it's current "facelift" guise to pre-facelift is something to consider.
SIDE:
Skirts from 500E.
REAR:
Bumper: I decided to use the 500E's rear bumper in lieu of the AMG item.
Wings: Here is where I am having problems and would like to tap into the general and collective wisdom of the list.
I have looked at several conversion pics.
1) E36T. 124-092.
2) An M119 motor in an E320T conversion with flares front and rear.
3) A 500E that has it's top cut off and an estate top grafted on.
4) The Hammer Wagon.
5) The AMG E7.3T which I believe is currently in Russia but I am not sure.
The only one that "got it right" was the 7.3T. The other bodies, nice that they are, just don't seem right IMHO.
The 500E's bodies flares out a little and just to stick fender flares (from a 500SL) or quarter panels from a 500E without addressing the body flare makes the car look like a boy racers wet dream from a Demon Tweeks catalogue.
AMG did address the situation in installing wider wheels on an Estate
http://www.w124performance.com/docs/mb/W124/ page 10, but that's only wheel related, I don't think it flares the body out that much. In any event the estate's body cannot be flared out without major surgery.
I heard that AMG grafted the SL front fender flares on the 500E rear quarters and then put that on the estate but hearing and knowing are two different things.
Of course one also has to change part of the rear floor in the Estate. The left and right floor and wheelhouse have different part numbers (HWA) for the AMG E36T versions according to the EPC.
Then there's the wheelhouse, inner fenders, should I use 500E inner and outer or 500SL inner and outer? Or maybe those from a coupe?
The rears, unlike the fronts, are welded in.
I am reluctant to buy new rear quarter panels from a 500E and front fenders from a 500SL not to mention the various inner fenders and floor sections just to see if they "might" look right.
As a side note, the 500E front flares are bonded on regular 124 front fenders. No separate stamping dies were used for the entire fender. Hence the "executed in plastic" 500E fenders that were made. I'd like to compare, side by side, the SL front flares and 500E front flares. Seems unlikely that MB had new dies made for just the flares on one model but..... ???
When work starts I will post pics, and part numbers, but like anything else in life one needs a road map, a plan, before ordering and cutting.
So... any suggestions, comments, etc., before I open the wallet and buy cutting disks are more than welcome.
The suspension has the usual tried and true upgrades.
Front: Bilstein Sports, Limo bar, 500E brakes, sportline bushings, 7.5X17 AMG Mono II with 225/45/17s.
Rear: 500E sway bar, sportline bushings, 500E brakes, 8.5X17 AMG Mono II with 235/45/17.
Wheels spokes are painted Malachite Green and rims are polished.
Interior: Burl Walnut replaced the Zebrano trim, mostly because I like saying the German word "Wurzelholz."
Thanks for any input.
Kind Regards,
Ron
500E
E320T
TC
120
356
MGA Deluxe
Bob Jackson Single Seater with 10 (TEN!!!), forward gears.
Ghibli
JD 318 "Monoposto" in Lotus Livery.
Continental R
and more junk laying around.
So.....
BODYWORK.
FRONT:
SIDE:
Skirts from 500E.
REAR:
1) E36T. 124-092.
Kind Regards,
Ron
500E
E320T
TC
120
356
MGA Deluxe
Ghibli
Continental R
