W124 E320 ASR defeat?
Discussion in 'Electronics' started by XJguy, Dec 6, 2018.
  1. XJguy
    XJguy Member
    44
    May 15, 2013
    NY, USA
    Car:
    1994 E320 Coupe
    Does anyone know how to disable ASR and keep it off without disabling ABS?
  2. grober
    grober MB Club Veteran
    25,898
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  3. OP
    OP
    XJguy
    XJguy Member
    44
    May 15, 2013
    NY, USA
    Car:
    1994 E320 Coupe
    I have the snowchain button, but it only defeats it partially and very briefly. I need to be able to shut it off totally and keep it off until I turn it back on.
  4. grober
    25,898
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    It would appear that the switch alters the slip threshold to allow the wheels to spin a bit to drive out of snow rather than defeat the system completely as you say.
    http://www.w124-zone.com/downloads/MB CD/W124/w124CD2/Program/Chassis/42-0800.pdf#page=17
    Unfortunately since both ABS and ASR share circuitry so it would appear that disabling one would switch off both! It might be posssible to downgrade the system to an ABS only system by swapping control units and a bit of rewiring but MB control units are essentially black boxes and don't know if anyone has tried this?
  5. grober
    25,898
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Apparently it can be done according to this . Its under Performance upgrades/ 4-1-06 - ASR Defeat Installation
    Rik Johnsons Mercedes 500E
  6. OP
    OP
    XJguy
    XJguy Member
    44
    May 15, 2013
    NY, USA
    Car:
    1994 E320 Coupe
    Yes for the V8 cars and for the newer cars it can, relatively easily. But so far I have not found anything for the pre 96 six cylinder cars.
  7. OP
    OP
    XJguy
    XJguy Member
    44
    May 15, 2013
    NY, USA
    Car:
    1994 E320 Coupe
    I just had an idea, if I were to provide a constant voltage to the wire that sends the throttle position location signal to the ASR computer, the car won't know its accelerating, this might be enough to fool the ASR while still keeping the ABS fully functional.
Share This Page
