So, that should mean he has the throttle arrangement where you first adjust the throttle cable correctly and then adjust the pressure cable so the two little arrows line up?
(although if the up-changes ARE happening at the right point it suggests the pressure cable is OK? - suggesting vacuum connection as the next point to check)
