Hi All First post here and I looked at the others and YouTube but can’t find my issue. In one thread I found that if the wire to the temp sensor on the thermostat body was blue and not green I have a new loom. It is so I’m assuming the loom was swapped out before I bought it. Car is an 2994 A124 E320 originally a German registered car. Looking at the loom in detail and comparing to the posts I’ve seen I have at the front of the engine two connectors that are loose and no vacuum unit to connect to. No vacuum tube either that others seem to have. Also their is a complex conector that is also loose on the left side of the engine after the inlet manifold and I can’t see where that goes. Does anyone have any idea why this is so. The car seems to run just great except for auto gearbox flaring but that’s only recent.
Photos attached
Thanks for any clues you can give me
Photos attached
