MercedesintheBlood
Hi All
So onto the next job....
Noticed the electric aerial on my w124 300E 1991 was not working. The radio comes on but just a load of white noise, and I could not get the aerial to go up.
I took a look behind the liner in the boot, and noticed an un-connected red wire.
So the only wires that were connected were a black wire which I think is earth connected to the metal frame.
The blue cable coming out of the aerial unit to connected to the brown wire coming out from the other side of the boot.
I removed the aerial after several hours, the nut holding it in places just kept spinning and I couldn't get to the other side to hold it whilst trying to unscrew it.
Finally removed the aerial unit.
So from the aerial unit there are 3 wires. Blue, red and black.
I could get the aerial to go up by connecting the red and brown wire, and then touching the blue wire (read on other forums this the wire that makes the aerial go up and down) to both the red and brown wire. If I take the blue wire off then the aerial goes back down.
I removed the stereo system unit, and could see a 2 brown wire that were not connected. Looks like some electrical tape was either holding them joined together or one end was taped off...
So what I would like to know is how do I correctly wire the aerial unit to the 1 brown wire coming from behind the boot area.... ?
