W124; electrical connection behind Headlight Switch
IslanderRE
Hello all,
[/IMG]
I found this electrical connection point located close to the headlight selector switch on my W124 coupe but I have no idea what itis for or what should be connected to it.
If anyone could help; I'd much appreciate it.
Thanks,
Islanderre
grober
MB Master
Perth, Scotland
W204 ESTATE
Mercedes of that age often have redundant wiring connections that remain unused in certain models. There are at least a couple of other electrical connections on that block already which will have some function. Unless you find some obvious disconnected wiring plug "dangling" nearby you can safely assume its not required in your particular model.
OP
OP
I
IslanderRE
KTH286 and grober,
Many thanks for the replies lads...... no mine does not have the headlight wipers.
Cannot see anything that should connect to it so will press on and box up the area under the steering wheel.
thanks again,
Islanderre
