isobars
- Dec 20, 2009
- Location
- Portugal, Belgium + Lancashire
- 300SD'79, E300TD '95, 300TDT '82, 280CE '84, 250L '84, 300SEL LPG '91, 300D '80, 300CE '91, 300E '89
Hi Everyone,
I’ve just sold a 210 Estate and with the proceeds I would like a W124 Coupe.
I’m not especially interested in high power, but would prefer it given the choice between a 230 and a 300 for example, however, not at the expense of hassle.
After having spent a few days digging around, I’ve come up with the following.
I’d be really grateful if anyone would give me a little – or a lot – of feedback about the conclusions I’ve drawn which are these, so far.
The 103 and 104 engines are both likely to need head work along with timing chain gasket replacement, not because of miles but because of age. So by now it should have been done, and if I can’t prove it, then budget for it.
Better head gaskets were fitted from 1993, is that correct, please?
If they were better, then what would be their lifespan? Should I look for evidence of a change purely on miles rather than age?
Post 1993, all engines are prone to wiring loom failure.
If the above is correct, is it a choice of a wiring problem, or the gasket problem?
And if that is the case, why would anyone take the gasket problem apart from the love of an easier engine to work on – the M103?
Is there the same gasket weakness on M102 980, 2300, four cylinder motors?
The more I write, the more I think I should look at a W123 280CE, or is that even more problematical??!!
Any thoughts most gratefully received.
Best wishes,
Paul
Best wishes,
Paul
