W124 ENGINE CONTROL UNIT
Deanthedub
Essex
A124
Hi new on here like to say Hi, had various mercedes over the years, currently have a daily 1995 a124 220 and recently bought a 1994 a124 320 project.
Anyway bought the latest 1 cheap as it had sat and various damage and pilfering had occurred the engine management unit (double plug 1 behind battery) being 1 thing stolen does anyone on here have 1 laying about they want to sell, many thanks in advance.
They're coded.
Pick one up with the same number on - no problem swap it out ,,mind it must have the same number ..talkto Rob
You talk about code.. a code for what ? You mean a part number of your unit to rteplace it .. talk to Rob he will know what it is you need..
Not the part #. HFM units (with a part # beginning 017 or higher IIRC) are not plug & play the way PMS units & earlier ECUs & ICMs were, they're coded to the individual car.
Dean, what's the VIN of your car? That's the only way to discover what was originally on your car.
This is like yours yes ? merc no A016 545 60 32 or bosch 0 261 203 492 not saying this is for your model but it is for the 320 talking £150 on ebay .
Yes there is a few on ebay but slightly different part numbers, I was told as long as its for a earlier (no remote locking glovebox etc) it will plug and play but gstting mixed messages
You can do a search yourself if you go to any Mercedes parts distributor .You will need your vin number .On line its easy .Whats your vin number .And i will see what i can find out to-morrow .Or may be some member can save me some time by looking it up for you .
CONTROL UNITS MERCEDES E-KLASSE [Car] [CHASSIS] (EUROPA)
ITEM 114
Thanks for that so am I right in thinking that as mine has cruise I need 1 of these:
0185456732 (43)
0165455732 (43)
0165456032 (43)
Nope you are not missing something- these units vary depending on chassis no, market, options fitted, KAT or non KAT ASR etc. I'm afraid the empirical approach in the event of ECU failure is look at the existing part no and look for a direct replacement or nearest equivalent. An option not open to you unfortunately.:( Rather than give you an answer that might be wrong I posted the link just to illustrate the possible permuations. :oops: The only thing I can suggest is make a list of the options you have fitted and post them on here and hope someone is kind enough to post up their own ECU number for their car that is a very close match to yours??
Otherwise its a ECU or MB EPC specialist familiar with your vintage of car.
This is a hard one to sort out ,,,you see in the picture it would be one of those ecu but for the right one you will need more information,, these dont cost pence but mega bucks .. But you do have something to go on with the help of Grober . You need a member thats got this model and to ask him very nice if he might take a look for sure . Mine is a W124 260 E 1989 no help at all .But to keep the post alive,, so you can to get more help .,,
