Just noticed a couple more things;
1) The wood paneling on the rear door looks damaged.
2) Aftermarket speakers fitted in rear doors (leaving big holes)
3) Wood paneling on front door doesn't look good either, plus looks like it's held on with screw at rear top!
4) Steering wheel doesn't look original, star looks wrong, should be shiny.
5) Aerial fitted to front centre of roof. (possible leaks) Though a common fitment to TE's
6) Left hand side headlight different, off newer model type bonnet.
7) As said, headlight wipers missing.
8) Also the right rear door just doesn't look right, or the fuel filler cap.
9) The boot shouldn't be open like that, as soon as you have it in that possition it should self-close.
Hope that helps, cheers.
