sjc123456789
Hi All, I'm a bit of a sado with cars and have a problem selling them...
My favourite is a 92 320ce - vin WDB1240522B88....
Like most, I've a problem with the engine wiring loom which I've taken off to replace (it wasn't giving any problems but i decided to replace it while doing a very deep clean / restoration). luckily I've been able to find most parts needed, some salvaged (with new pins) / new wiring and some from Mercedes Wakefield (who have been fairly helpful).
i have two problems though -
1 - i need a wiring diagram, the one I've picked up from the web suggests that pin 8 from the main 44 pin ecu plug is a pink coax (centre) that runs to the camshaft position sensor (ground / shield is connected to 19). on my vehicle it looks to he a green coax. Just to add some confusion, pin's 29 and 30 are also a green coax to a similar connector (129 540 22 81). i believe this is the crankshaft position sensor (other was cam)
2 - i need some of this coax, the colours on my vehicle are (centres) grey (slate?), green, yellow and purple (violet). could do with about 2m of each.
can anybody help with the diagram or sourcing the cable (I've tried the guy's at VWP ltd in Ilkeston, they don't do the coax).
thanks in anticipation. Simon.
