300CE24V
Hi guys, loking for some advice on how i can progress an issue i have got since my car has come back from paint.before the car started starightaway by the first turn, no idling issues, kickdown responded near enough instantlythe car has been sitting idle for nearly 2 months, doing very short journey while it got a full respray, they also killed the battery and had to use a booster to get the car going. another point was the fuel was very low in the carsince i have had it back it really struggles to start, when it does get going it idles very low (below 5000) you then have to give it several minutes to warm up a bit otherwise if you engaged in D or R and rev it it will cut out, i have no acceleration power whilst it is in P, really struggles to rev uponce it gets going i get a lag in accelartation, but the car moves quick enough when i put it in gear, but struggles for a bit when i shift up.i have no acceleartion at all when i am trying to pull away on a slight incline (doing 50 through road works, car has four adults in it, reach the end of the roadworks and it just didnt want to go anywhere)also when i engage the kick down i get nothing for at least 2 seconds before it remembers to engage iti have only managed to clean up the breather unit which looked ok anyway. like i said the car before the paint job was running so beautifully! that was the only reason why i went for it as mechanically the car was perfect.any expert opinions i could try myslef, or take to a good mercedes garage in and around west london\surreyThanks
