Hello everyone,
Thought I would start my own thread as I bumped an old one and not sure if it will get any replies, apologies for replicating a post.
Haven't posted for a while but have been a member for a few years, moved from a w120 to a w124 in the last year.
So my ignition barrel will not turn to position one! Everything was working fine up until I got into the car this morning, I have tried everything such as graphite grease/spray, wiggling the key while turning steering wheel, using a soft mallet to try and get it loose, using pliers with the key to add a little bit of leverage without snapping etc but still no go!
From what I understand, my next step is to cut off the black surrounding that covers the barrel, is that correct? Im assuming once I cut this off I will be able to access the spring that is holiding the barrel in place.
Please correct me if Im wrong or do let me know if there is anything else I can try. Thank you.
