darreningram
- Oct 30, 2007
When the indicator stalk is used to do single right indication it doesn't work- it is fine when fully depressed to indicate a full right turn and will switch off after the turn as normal. I suspect a worn connection but any help would be appreciated. I am a little reluctant to dismantle the whole thing as it does indicate right normally- it is really only a nuisance when changing lanes- is there any easy way to get some cleaner onto the connection? Thanks in advance
