Hi all,
I'm new to the forum and hope that someone might be able to help.
W124 E280 Estate which had a couple of bulbs out on the aircon controls and one of the air vent lights.
Used the forum to find out how to get to them and duly changed them. All went well except for one tiny detail........now none of the backlights work.
No lights on the window switches, gear selection, heated seats, aircon the rear-wiper/hazard switches and the air vents....all dead. The actual switches work fine and none of the fuses seem to be blown.
Lights in the main instument cluster seem fine, except for the external temp light, and the dimmer on the instrument cluster works OK. So at least the car is OK to use at night.
My question is therefore is there a seperate fuse/relay for all these other lights or might I have dislodged something at the back of the radio, which I removed to get the fascia off the aircon.
The only other thing I can think off is that one of the bulbs in the air con (the left hand rotary switch that controls the fan speed) was broken and took some fiddling to get out so I might have broken something behind there.
Anyway anyone got any ideas? If not I'll be off to the auto electrician.
Cheers
David
Cheers
David
