thanks for that.
what is housed in front of the drivers seat under the carpet, on the outside edge, housed in an elongated triangular shaped plastic cover?
No Thats not the hot air duct, that sounds like the ducting for the wiring loom.
thanks for that.
How is the water getting in though Boss, was it because the window was left down in the rain??
the water got in from when washing the car, and after the window motors were replaced, the indie did not replace the screws on the mount and did not reseal it.. hence this issue has arisen from lack of seal behind the interior trim panel.
rigel said:Great info and research Boss, thanks for sharing.
Mine got wet in much the same place.
The rear seat supports (missing in your picture ~main view of osr panel with trim removed.) had started to tarnish due to the water, and the rear edge of the cabin side lining had evidence of water marks running down the rear edge when I removed them. Im still not sure how it was getting there in the first place though.
I am now going to check for missing screws and that the blacktac sealer is not compromised in any way.
Is this blacktac the only waterproofing between the window cavity (where the water runs when it disappears between the rubber seal and the rear window) and the inside of the car?
On a slight tangent, I read earlier in the post that there are instructions for adjusting the windows. Does anyone know where I could find these?
Regards. R
Yes . For the motor not regulatorDee-124CAB said:boss was all this removed when you had the window regulators changed?
No noWDB124066 said:Well spotted Jay! That is indeed the cable duct, the hot air duct runs next to it...........
I wonder if they knew why the sealant was there - what it's significance was. Hope they don't try and blame you for leaving out the screws etc......
Boss, are you saying you have a leak between the top edge of your rear windows and the hood, when you spray the hose upwards directly into that area. I'm not so sure this should be happening, from where do you first notice wind noise with the top up, is it in the same area......
I have a copy courtesy of our new Zealand w124 friend. Pm me your email addy
Put it up here rigel for a few minutes then delete it. Then I can send you a copy.
Be good to meet up with the cabbie guys in the UK, that would be something to get get them all together in the same room, have you seen the photos of the German GTG's........ I just maybe in the UK and Europe later in the year.......??
dilon was it danny who messed up the job?
