W124 M111 960 fault codes.
Robbarr88
Hull, United kingdom
W124 e200 Saloon.
Hi Guys.
So i made one of the blink testers today for the mercedes to try find out the fault codes i used port 6 in the 16 pin port.
My cars a w124 e220 m111 960.
I got the following codes and i was wondering if someone can confirm that iv got the codes correct i used the fault codes from peach parts forum.
So i got
3 blinks - lambda sensor
4 blinks - air flow meter
5 blinks - egr faulty (egr was unsure as its petrol?)
6 blinks- idle speed control
8 blinks - coolant temp open circuit.
This is what i got from peachaparts but wanted to double check that they were correct and if someone in the UK can confirm incase the models were different slightly.
My faults have been wont idle at all at low revs cuts out and stalls above 2000rm is fine, car was stood for almost a year so its just getting it back up and running properly now.
Thanks in advance guys.
Snap just built one myself , what year is your car ? on mine I'm sure Pin 6 was SRS tensioners safety belts etc and Pin 8 was my Lambda ECU codes etc Mine was a 1993 220TE ie M111 engine with a Cat
Mine was a E220 1994 model with CAT also, im hoping once i get home i can get the bits fitted too it and hopefully solve the problem
