W124 original suspension please help
Here is your data card
  • 300e-datadard.pdf
Another question guys I'm thinking of going for mono block aero 2 AMG rims 17" what's the correct offset and do I go for staggered or not?
Hi all I am a new member I just bought a w123 230 e 1985 near mint condition I’m looking for some amg penta wheels can any one help ?
BUMP
Fourty two millimeters for a 7.5J rim.
Thirty millimeters for a 8.5J rim.
You might want to check with AMG to see if you need to roll your fenders, I'd suspect you would, if they aren't already, otherwise you may drag a lip down.
You should lern to trust your own guts, it's your car.
So then guys I've ordered original coil springs from suplex Germany and BOGE Shock absorbers hopefully they will be here next week or so., So just to clarify I can lower the car 10 to 20 mm with the shim pads or coil spring pads????
So if I get thinner pads like for example 8 mm will that lower my car or higher it?
