Could anyone explain the workings of the OVP in relation to the fuel pump relay please. My 1995 W124 e220 always starts on the button until yesterday..... When I turned on the ignition I didn't hear the fuel pump prime and I think, but may be mistaken, that the dash warning lights were slightly dimmer than normal and it wouldn't fire up due to the fuel pump not running. Had to go out so couldn't look any further but read up on fault and it pointed to fuel pump relay & or OVP.That evening put key into ignition and it started first time ! Just to check I removed both relays pulled them apart but couldn't see anything obvious, no cracked solder, burning etc.Re fitted and still ok but cannot trust it so have ordered a new OVP from Mercedes. Now how does the OVP work with the pump relay ? Does it switch the supply to the pump relay or monitor the relay whilst running ? I suspect it monitors after starting as the pump relay has a 30A fuse in it & the OVP a 15A in it.The pump defiantly wasn't running when it wouldn't start but runs fine now so I don't think the pumps at fault as they usually work or don't. Any ideas please ???
