W124 part number needed
Discussion in 'Bodywork' started by rigel, Jul 7, 2011.
  1. rigel
    rigel Hardcore MB Enthusiast
    249
    Oct 31, 2010
    The sunny side of Kingston
    Car:
    W124 cabrio
    greetings all,
    I'm looking for a little help in finding a part number for my 124 that my local MB parts dept don't seem to be able to locate on there EPC.
    the part in question is the rubber plug/grommet that is fitted over the holes (2 on each side) in the rear side pannels that are located under the plastic cladding piece just behind the door.
    i think the hole and nut they cover are the rear window adjustment nuts?:dk:
    at the moment mine are covered with windscreen washer lids according to MB.
    regards.
  2. Scott_F
    Scott_F Hardcore MB Enthusiast
    3,942
    Mar 12, 2010
    As MB will probably want to charge about £10 each for a couple of grommets you may be better off going to your local scrapyard.
  3. whitenemesis
    whitenemesis MB Club Veteran
    15,976
    May 7, 2007
    Car:
    Lexus RC300h F-Sport 2019
    could it be #16 in the attached?
    1 person likes this.
  4. OP
    OP
    rigel
    249
    Oct 31, 2010
    Car:
    W124 cabrio
    thanks for that whitenemesis,
    not sure if that's the right part, form the picture it doesn't look round to me.
    the bung/plug/grommet i'm after is to plug a 30mm diameter hole that needs to have some sort of rebate in it to allow for the bolt located within to stick out a little, whalst still remaining covered.
    regards.
  5. OP
    OP
    rigel
    249
    Oct 31, 2010
    Car:
    W124 cabrio
    it may be to cover bolts 22 and 24 shown above, if they are the bolts that are visible from outside the car through holes in the rear side pannel.
    the bolts in question seem to have an adjustment nut at the centre which sits proud in the hole to be plugged.
    regards.
  6. whitenemesis
    15,976
    May 7, 2007
    Car:
    Could you post up a picture?
  7. OP
    OP
    rigel
    249
    Oct 31, 2010
    Car:
    W124 cabrio
    will try, not having done it before, not sure how i will get on.
  8. nick.ged
    nick.ged Hardcore MB Enthusiast
    706
    Sep 13, 2009
    midlands
    Car:
    mutty the nail; wide body amg 124 coupe
    definitely a scrapyard 'purchase'
  9. OP
    OP
    rigel
    249
    Oct 31, 2010
    Car:
    W124 cabrio
    PHEW, just managed to upload a picture.
    These are two of the four holes that need re-grommeting.
    As is visible, the centre nut protrudes slightly, I presume for adjustment.
    [​IMG]
  10. jaymanek
    jaymanek Authorised Forum Sponsor Authorised Forum Sponsor
    16,400
    Nov 29, 2002
    Nuneaton Warwickshire
    Car:
    are we talking exterior of the car or interior?
  11. jaymanek
    16,400
    Nov 29, 2002
    Car:
    The only one I can see is A0009974020 which is listed as a 32mm bung and says "side member, outside bottom.
    The other one is probably a1139870044 which is a 20mm plug
  12. whitenemesis
    15,976
    May 7, 2007
    Car:
    Don't see any pictures??
  13. OP
    OP
    rigel
    249
    Oct 31, 2010
    Car:
    W124 cabrio
    Thanks for that Jay,
    We are talking outside; they cover the two holes in the lower side panels, with what I believe is the rear window adjustment nuts behind them.
    my local MB dealer parts dept. are getting one of the 32mm "side member outside bottom" in for me to test on the car, it has to come all the way from Germany at £1.20.
    They are not sure that it’s the right part, because it didn’t seem to have the recess for the nut head, but want to try it out anyway.
    will post our findings!
  14. OP
    OP
    rigel
    249
    Oct 31, 2010
    Car:
    W124 cabrio
    not sure what i've done, the pictures are visible on the thread i'm reading on my computer.:dk:
    I copied it from a picture i've uploaded to my gallery.
  15. jaymanek
    16,400
    Nov 29, 2002
    Car:
    the problem with grommets is that they arent shown where they actually go on the EPC. They just have their own page and sometimes a brief description of location.
    This is done because the same parts may be used in various places in the car.
  16. OP
    OP
    rigel
    249
    Oct 31, 2010
    Car:
    W124 cabrio
    hopefully this will work,
  17. OP
    OP
    rigel
    249
    Oct 31, 2010
    Car:
    W124 cabrio
    maybe this will work??
  18. whitenemesis
    15,976
    May 7, 2007
    Car:
    Yes those I can see ;)
  19. WDB124066
    WDB124066 MB Club Veteran
    6,176
    Apr 17, 2009
    Car:
    1996 E320 Sportline Cabriolet x 2
    110 987 0544
    There is also another number on them 02 5370/1
    They are solid but the centre is very thin to allow it to distort around the nut/bolt.
  20. OP
    OP
    rigel
    249
    Oct 31, 2010
    Car:
    W124 cabrio
    thanks for that W. will get onto the parts dept tomorrow.:thumb:
Share This Page
