Evening everyone,
I'm after some advice about my W124. I went on a long run up to Birmingham area (120 miles or so) a couple of days ago. For two hours all was fine and the car was normal, for the last half an hour as I came off the motorway the car seemed to be missing and there was not as much power as there should be. I carried on and took it easy.
An hour later I left and the car was still missing, no problem I thought I'll take it easy it must be something basic. Again, maybe 1 hours 30 mins in the car started to loose a lot more power and felt very rough/started shaking. I pulled into the next services to investigate.
I've looked into it and jacked the car up and had a good look at everything but don't have a clue what it could be. The symptoms are;
Lacking a LOT of power.
Missing a lot.
Running very rough.
The engine is shaking much more than it should.
The car is a 3.6 straight six.
If anyone has any ideas as to what may be causing this please do let me know. I will be taking it to my mechanic as soon as I can get it booked in but I'm just hoping it's nothing major!
Thank you
Missing a lot.
Running very rough.
Thank you
