Hope you can help a newb with a leak.....
After a run the radiator leaks (drips) from the left bottom corner at rear edge (if standing in front of car looking back). It seems strange to me because it's intermittent, sometimes about a pint will drip out other times nothing?
From the photo it could be the join between the finned aluminium radiator section and plastic side panel (some corrosion evident)... any ideas, is it going to be expensive or do you reckon a course of rad-seal will cure it?
