W124 rear suspension - HELP!
mikeyb1049
Guys
I've got a 95 220 coupe and just now when I jumped on the brakes got an awful banging/rattling noise from the rear end. Got the wheels off and the brakes were fine BUT found this instead (see pics) - any ideas what's happened and what I need to do?!
Mike
WG M-B
Auhorised Forum Sponsor
N/W london
C63 Wagon in black
Looks nasty. A new subframe bush would be a good place to start fella!
OP
OP
mikeyb1049
mikeyb1049
Thanks!! Is it a DIYable job? I'll turn my hand to most things but if I need special tools I'm screwed...
grober
MB Master
Perth, Scotland
W204 C200CDI Estate
That's the front? mount for the rear subframe. Its difficult to tell from the pictures waht exactly has happened but there are 3 possibilities. One the subframe has failed two the mount has disintegrated three the section of the main body frame where the subframe mounts has rusted through. ITS A VERY COMMON FAILURE POINT ON THESE CARS. Its usually the front ones that go first- that and the rear sill jacking points-- all around the same place. Best get both sides repaired if the other one looks at all suspect. Unless you are an experienced welder its not a DIY job I'm afraid. A few more pictures from different angles might help a more accurate diagnosis
here's avideo of a rear subframe removal its for a190 but the w124 is very similar [YOUTUBE]StyMryBrtnk[/YOUTUBE]
Dieselman
Banned
Peugeot 403 Convertible
The inner metal tube has collapsed and broken free of the rubber bush.
A hammer and chisel will see the old bush out and then press the new one in with large water pump pliers or using a jack.
grober
MB Master
Perth, Scotland
W204 C200CDI Estate
If its just the mount as DM says then breath a huge sigh of relief and renew both front bushes. If you are not used to working under cars and using a bit of brute force in a controlled manner I suggest you leave this to the pros. Any good local back to basics garage should be able to do this for you. ECP does Lemforder ones which are fine.
OP
OP
mikeyb1049
mikeyb1049
Thanks grober - doesn't sound great does it... I'll get some more shots from different angles in the morning to see if that gives you any more info at all. I take it there was something (a bush?) in there before it disintegrated? I can't picture what it looked like previously and can't really did anything to look at on the Internet.
OP
OP
mikeyb1049
mikeyb1049
Brilliant thanks for the help guys - that's my day sorted tomorrow then!
