janner
- Oct 13, 2003
- E320 Turbo Technics
Sounds like you needed a better mechanic. If he had diagnosed the gasket in the first place you wouldn't have needed the timing chain or tappets.I have spent 700 pounds on a new timing chain, tappetts, manifold gaskett .. it went back to the garage twice as the first set of tappetts were pressumed faulty. They werent !!..so it went back again and it was the manifold gasket causing the tappett noise
Really? There are only a few rear suspension bushes that normally need changing after 14 years and they're not that expensive. If it clonks when you change gear it's probably the front propshaft coupling (£40).i now need a whole new rear suspension system
Maybe that's why it was for sale?ahhh cylinder head gasket
I'm sorry that you have had a bad experience with your Mercedes but I really believe that the W124 is one of the best engineered cars out there. After 14 years though, some things ARE going the need changing (like suspension bushes and window motors).
It sounds like you were unlucky with this car and the mechanic.
