I have a front coil spring problem on a 1991 w124 260E.
The spring has broken at the lower end and I found a broken off segment containing two coils on the ground. The spring is now at an angle and poking into the inside rim of the wheel (see pics). The top section of the tyre has disappeared up into the wheel arch and as a result I cannot turn the wheel. I cannot move the car forward or back because the spring is digging into the wheel.
I am thinking I might remove the wheel so the rest of that spring will drop out. I am not sure if the wheel can be removed easily as the tyre is being pushed right up against the inside of the wheel arch. I have not tried jacking it up yet.
Is it normal for the wheel to be compressed right up into the wheel arch when the spring breaks? Do you think it is safe to take that wheel off?
