Bill_33
- Aug 29, 2008
- Location
- Hampshire
- A160,(W169) previously 300TE - 300CE, E280TE
The front springs, wishbones and ball joints have just been replaced on my 300TE.
A few questions:
1). The front "ride height" seems high - the garage that did the work, (an MOT Centre), told me that the height would "settle down" after a few miles......is this true?
2). Does anyone know what the ride height should be in cm.....say when measured from the centre of the front wheel to the lip of the front wing.
3). When the springs are replaced....is it normal to replace all four?..is that the problem........do the rears need replacing
4). The back end may need some work.........if there is a problem with the SLS system on the Estate, can this be replaced by fitting normal "shocks"
Any other comments that could help me?........my once 300TE....which I thought was OK....has now had lots of parts replaced and may need some other work, (£££)
Cheers
A few questions:
Cheers
