smoothcoupe
- May 9, 2005
- Location
- WEST YORKSHIRE.
- MERCEDES E55K-2001 AUDI S8-MERCEDES 300CE 24V SPORTLINE
How do I remove the steering wheel on my 1995 e280.
When you have loosened the center bolt leave it in a few turns till the wheel has come loose on the splines. It's easy to hit yourself on the chin when it comes off with a rush.
On the back of the wheel you fitt find 2 torx bolts, you need to undo them to remove the airbag. You then need to detach the airbag lead, and remove it.
Below you will see the Hex bolt, get someone to hold the wheel while you undo the bolt. It can be very tight, Id advise a breaker bar, as Ive broken rachets before.
DO NOT mess with airbags until you have disconnected the battery and the airbag module ( in the passenger footwell of the W124 ) .
I have detailed instructions under my 500e section and 190e section that should answer all your questions concerning airbag/steering wheel removal as well as upgrading to newer style steering wheels and what is necessary for the conversion.
www.2phast.com
