I had a look at some similar threads using the search function, and it seems like others experience the "stiff throttle pedal" on their W124s as well.
It's the common problem of it being stuck at one point, when you are trying to push it down gently.
I tried spraying WD40 on the throttle cable, but it didn't make any difference...
So I thought I would buy a new one, but can't find it anywhere?
Are they all the same or vary depending on the engine? And how hard is it to change it?
