I got the nearside front bush done last night , once the ambient temperature had cooled down a bit .
Slightly worryingly , both mounting bolts came out very easily . The front bush was completely knackered : I was able to lift the middle out with one finger as it had completely separated from the rest of the bush . It took a while to hammer and chisel away at the rest of the bush , but got it eventually . I lubricated the new one with Fairy liquid and it went in fairly easily , using a jack under the corner of the subframe to press it in against the underside of the car . The new bolt was VERY tight going to get in .
The rear bush seemed completely intact and solid - so I left it alone - I'll put some thread lock on the bolt just to be on the safe side .
Just got to re-hang the back section of the new exhaust that I only fitted the other week then had to take off again , and paint the fuel lines , before I do the other side one night this week .
